Old 07-17-2007, 04:54 PM   #1 (permalink)
MotQNNJ is on a distinguished road
Rating or review Review: Seidio Rubberized Hard Case For The Extended Battery
I recently purchased a bundle for the rubberized extended battery case and 2100 mAh battery. I have a Verizon Wireless phone and the case fits perfectly. I am 100% satisfied. The only drawback is that it is hard to get the two sides apart, but that can also be a good thing.
I wanted to post this in the new reviews section, but there wasn't this item there. I did submit the proper information to try to get the review process fro this case started, but I don't know if I did it correctly, hence me posting here.
I actually was hesitant about purchasing this case due to another review on here: http://www.everythingq.com/forum/mot...clip-9047.html
due to the fact that the case flies apart upon impact with the ground. But, if it takes the intial impact, that is a good thing.
I do have a VZW universal PDA pouch. Adding this extra protection makes the closing of the pouch a little difficult. But, it does close and stays closed. I might invest in the holster for this case, if needed.
I feel if you have a VZW Q, this case should fit your phone just fine. I have attached a picture for reference.
since September 2006, 1650 mAh OEM extended battery, and updated with MOL3.
MotQNNJ is offline
Old 07-17-2007, 08:58 PM   #2 (permalink)
you should post this in the new review section as well!!
Old 07-18-2007, 10:59 AM   #3 (permalink)
Administrator
chris's Avatar
chris has disabled reputation
Send a message via MSN to chris Send a message via Yahoo to chris
Rating or review Adding new products to review section isn't very clear
Sorry, the adding of new items is a bit confusing. I've gone ahead and added this case. Please feel free to add your review of the Seidio Super Slim Case here.
To avoid confusion, I've removed the ability to add products to the review section. If something isn't listed, just drop me a PM and I'll add it. Don't worry, it's not you. The same issue happened here and at Everything iPhone. It's not as clear as it should be.
In any event, I welcome and look forward to seeing your review.
-Chris
Everything Q Store
Everything Q Software
Sign up for the Everything Q eNewsletter
Just get your Q, then read the Moto Q New User Guide
chris is offline
Old 07-21-2007, 09:20 AM   #4 (permalink)
jdfitz is on a distinguished road
Default seidio rubberized hard case for extended battery
I noticed that none of the ads for the seidio rubberized case mention the extended battery - whether or not there is a separate option for this. Can you buy the one that seems to be listed and expect it to cover the 2100 battery? jdfitz
jdfitz is offline
Old 07-23-2007, 10:32 AM   #5 (permalink)
See: http://www.everythingq.com/cases/cas...38/#jreview_28
http://www.seidioonline.com/index.asp?PageAction=VIEWCATS&Category=927 advertises both the extended battery and the slim. My review above is for the extended (either OEM 1650mAh or 2100mAh).
It covers the 2100 battery just fine. I originally had the 2100 battery, but did not like the length of time the 2100 stayed charged.
MotQNNJ is offline
Old 12-10-2007, 01:37 AM   #6 (permalink)
breitt is on a distinguished road
Default Updates on Seidio Rubberized combo?
I tried the rubberized case with the Sprint grey Q back in June when the case first came out and it did not fit together properly over the phone. I subsequently returned it, but am now in the market for a case again. Have there been any modifications/improvements in the Seidio case with respect to the Sprint Q since then?
breitt is offline
Old 12-15-2007, 11:06 PM   #7 (permalink)
johndudle is on a distinguished road
You did not like the phone staying charged longer? Why not?
johndudle is offline
