Originally Posted by boomhower I ordered my Q this morning and now I need a case. Here are some things that I am looking for. It must either have a built in clip or be able to fit into a clip. |
I'm using an
HP iPAQ leather case. I bought it for my iPAQ hx2795 Pocket PC, but even though the hx2000 line was listed on the packaging, it was too small. I was a bit upset about that, because my old iPAQ 5550 leather case was getting old.
However, I was also looking for a case for my Q and thought I'd try the Q in the iPAQ case. It fit! It was a tight fit, but that's not necessarily bad.
It features a leather-covered metal belt clip, a magnetic flap, good thickness for padding and two SD card slots (which I use to store my MiniSD and MicroSD adapters). I like the magnetic flap and the fact that the Q lays on its side edge, which allows me to easily open the case and access the scroll wheel (useful for confirming Voice Recognition prompts).
Steve
