I have a Q9m and I bought a 2200 mah battery with a cover for Q. Then I bought an extened battery cover for the Q9m well it is not deep enough. Does anyone know where I can get a battery door deep enough to use the 2200 mah battery? Or should I just trash it and start over.
I'm not familiar with a 2200 battery for any of the Q's. There is the 2100 battery that's the same size as an extended battery and the 3200 that's larger than the extended battery. I'm assuming you meant the 3200. The fact that there's no battery cover for the 3200 that will fit the Q9m is the only reason I haven't gotten one yet. If you don't mind having a spare battery, I'd try getting one of the 2100 batteries (which work with the standard extended battery cover) and waiting for them to release a cover for the 3200. Or try doing an exchange.
