Old 04-05-2007, 10:50 AM   #1 (permalink)
themacgeek is on a distinguished road
Default Q battery question.
Hi guys i just got my Q for sprint i love it so far. I have had it for 4 days now i got it on monday. I was wondering what some of your thoughts are on battery. I can usually get through a whole day when i am online IM'ing people for about an hour or so a day and send about 15-20 txts and 10-15 phone calls around 5-15 minutes each. But i can see my self needing either a second battery or an extended. I was wondering how much bulk exactly does the extended add to the phone? Is it worht it? or should i just get a second standard battery?. Also do you think i should stick with the OEM motorola battery or go with a seidio does it make a difference?
themacgeek is offline
Old 04-05-2007, 01:34 PM   #2 (permalink)
dmaldo is on a distinguished road
It's not bad at all. I was worried about the same thing. It doesnt make it really bulky at all. It's great though, being able to get through the whole day and have 2 bars at the end of the night. I figured if I want to go out for the night and have my slim smart phone, just switch out battery. Otherwise its worth buying. I believe i got my motorola extended battery and ext. battery door on ebay for 39.99
dmaldo is offline
Old 04-05-2007, 01:40 PM   #3 (permalink)
thanks i think i am going to order one off of ebay as well. I found it for $34.49 with $4.99 shipping.
Old 04-05-2007, 03:35 PM   #4 (permalink)
Yeah thats what I bought it for.
dmaldo is offline
Old 04-05-2007, 03:44 PM   #5 (permalink)
i actually think i am going to get the seidio 2100 mah battery it is $49.99 but it is also 50% more life than the motorola extended.
Old 04-05-2007, 05:22 PM   #6 (permalink)
qnoob's Avatar
some have said that battery is so big that it seems like you taped a roll of pennies to the back of your Q. Can't find that post on here though.
qnoob is offline
Old 04-05-2007, 07:29 PM   #7 (permalink)
Question is, does the Sprint Ext. Battery back support the 2100 seidio battery? If so, i want to purchase it.
dmaldo is offline
Old 04-05-2007, 07:32 PM   #8 (permalink)
Yes it does see
http://www.seidioonline.com/index.as...ROD&ProdID=470
they say it is the SAME EXACT size as the OEM extended battery so it will fit with the sprint door ext. battery door but they offer a dark gray door now that will match the sprint phone. So i think i am going to pick that up.
