I have the Motorola 9QC, I am also using my laptop of a few years, an HP NW8000 strong workstation type.. I just can't part with it.
My laptop has a SD slot built in, it works perfectly for SD, I tried an SDHC 4GB card (new for a camera) and it would not work, wouldn't read it.
I want the most memory I can get for my phone, however, I currently purchased a Sandisk Micro 2gb with a mini SD adapter as well as a SD adapter for using it in my SD slot of my laptop... bye the way, I also have an SD-SDHC USB reader.
http://www.officemax.com/omax/catalog/sku.jsp?skuId=21497346&searchString=sandisk%20sd&c ategory_Id=null
I would at least like 4gb, preferably 8gb... but are they all SDHC?______
If so, SDHC should work through my SD-SDHC reader and not be a problem on my laptop correct?____________ I just can't use the laptops SD slot then... right?_____
I am thinking of just keeping the Sandisk 2GB KIT for the adapters and getting a 4gb-8gb SD Micro, I am assuming that anything above 2gb is "SDHC", seems to be what I am finding online anyway.
Tips, suggestions, GREATLY appreciated...
Thanks in Advance!
Edmund
