Originally Posted by sulster i can use the "standard" battery that came with my original silver Q in my Q9c. (The battery that came with the Q9c is technically a BT61. The other battery is at the office so I can't confirm the number right now.))
-HTH |
Thanks!
That means that the standard batteries have the same
physical dimensions.- My SSN 5783B battery has a capacity of 1130 mAh.- I live in Venezuela and the only
replacement battery I could find (on the web) is BT60; Does anybody know the capacity of this battery and if fits
the silver Q??
know t
