Old 07-26-2006, 01:15 AM   #1 (permalink)
Mystagogue's Avatar
Mystagogue is on a distinguished road
Send a message via AIM to Mystagogue Send a message via Skype™ to Mystagogue
Camera or Multimedia Leather Case = No HeadPhones
I have the leather case for Q, which has a couple holes carved into it so that the speakers and USB are exposed. But it does not have a notch for the headset!!!! Without the headset notch, I can't close the flap on the case. Is it me, or is this a major oversight?
I figure I'll have a seamstress (sp?) cut the notch and re-sow it for me.
Mystagogue is offline
Old 07-27-2006, 12:47 PM   #2 (permalink)
SDMahan is on a distinguished road
Which leather case is this? The Motorola case sold at Best Buy has notches at the top for headphones.
SDMahan is offline
Old 07-28-2006, 02:55 AM   #3 (permalink)
Mystagogue's Avatar
Its just called "Pouch for Motorolla." I'm not sure its manufactured by Motorolla. Nevertheless, after reading your post, I headed to a circuit city looking for a different case...and found something called the "PDA Pouch." It is a little more roomy (to hold larger smart phones), but its ~3/4inch snap-strap is narrow enough to permit the headphones clearance. I wonder if this is the one you have.
If yes, then I'd rather keep the one I have, and have a seemstress (sp?) doctor it up for me. I like the "sleeker fit" of the one I've got, above the generic "PDA pouch."
Old 07-28-2006, 08:24 AM   #4 (permalink)
The one I have is made by and branded Motorola. It is called the Q Carry Case with Belt Clip. It is a sideways case with a non rotating belt clip. You can check it out on Motorola's website under accessories. It is also listed on the Best Buy website.
SDMahan is offline
Old 08-21-2006, 04:21 PM   #5 (permalink)
jpmihalk's Avatar
jpmihalk is on a distinguished road
I have the leather Q Carry Case and it would work with headphones if I used them (it's the same as SDMahan describes.) I use a Jabra JX10 Bluetooth headset instead of the wired headset.
jpmihalk is offline
