Old 04-30-2007, 08:25 PM   #1 (permalink)
edweed111 is on a distinguished road
Music or Audio How do I hear my phone ring through my headphones?
I have a set of Motorola 2.5 headphones and they play music very well but the ring tone will not go through them when the phone rings. Am I doing something wrong? My Bluetooth headset works just fine. I get the ring in my ear, plays music, but it just doesn't work well for my working enviroment & thats why I need a corded set with earbuds. Can anybody offer any advise?
edweed111 is offline
Old 05-01-2007, 04:35 PM   #2 (permalink)
qnoob's Avatar
you learn something new everyday. i never knew you could hear rings with the BT headset, but NOT with a regular corded headset.
anyone know of a setting that'll turn on rings in a corded headset?
qnoob is offline
Old 05-01-2007, 07:11 PM   #3 (permalink)
mikemcq is on a distinguished road
are they music/handsfree headphones, does it have a built in mic for you to be able too talk to people. or are they stricly music head phones? I have a set that are for music that can be used as a wired headset, and i get ringing through them, if they are soley music headphones, you will not get ringing through them.
mikemcq is offline
Old 05-01-2007, 08:19 PM   #4 (permalink)
They are the type with the built in mic to take & recieve calls.
Old 05-02-2007, 01:39 PM   #5 (permalink)
abrigham is on a distinguished road
One thing to watch for - does your Q switch to the Headset profile when you plug in the headphones?
abrigham is offline
Old 05-03-2007, 09:41 AM   #6 (permalink)
Yes it does that automatically.
Old 05-25-2007, 05:40 PM   #7 (permalink)
sjcruiser36's Avatar
sjcruiser36 is on a distinguished road
I have the headphones that Motorola was giving away to Sprint customers that forgot to make it inside the box. When a call comes through and I'm listening to music the music will stop playing and the phone will ring, even the custom ringtones that I have setup. I can ignore the call or answer it by pushing the button on the mic/headset. When the caller hangs up, I don't have to do anything, the music will commence in about 6 seconds.
sjcruiser36 is offline
Old 05-25-2007, 05:41 PM   #8 (permalink)
Mine also switches to headphones automatically when the headset is inserted into the jack.
Old 05-25-2007, 05:45 PM   #9 (permalink)
FourTwenSesh's Avatar
Yes, it switches to Headset profile immediately as soon as you plug the phones in.
FourTwenSesh is offline
