AAAHHHH!!!! The famed extended battery question. My answer is yes, you need another(actually a real) extended battery. It sounds like the Verizon guys just gave you another standard slim battery.
I am a big advocate for
seidio products. Their extended batteries are great, and you have 3 options(
check them out). Depending on the size you want, which of course determines the amount of charge it will keep. I personally can go all day with the 1250mAh slim extended battery.
Also, I hear if you update your phone with the latest software it will preserve some battery life. Dont know if thats true for VZ folks, but I think its works for Sprint Q's.
Hope this helps... Enjoy your day
