I'd like to buy a cradle that will charge the Moto Q9h with the extended battery attached and also charge an extra normal size battery. I went to the everythingQ store and found the Motorola Desktop Charger for Q but the disclaimer says THIS CHARGER WILL ONLY WORK WITH THE STANDARD MOTOROLA Q. I also found the Motorola Desktop Charger for Q9c, Q9m, but I'm not sure what the differences are between the Q9c, the Q9m, and the Q9h.
Does anyone know if there is a cradle for the Q9h? Thanks.
This is the one I use and it does have the slot for the larger battery. In addition, the extra slot in the back of it also fits the regular and Larger batteries.
Contributions via PayPal? Yes, you can, it's my email address.
Nascar: Bumper to Bumper, 200 mph, 40 Professionals Boston: Bumper to Bumper, 70 mph, 400,000 amateurs
I have that one and used it on my Q but it will not work on the Q9C and probably not on the Q9M. These have a different battery doors that go all the way to the bottom of the unit. It is slightly fatter at the bottom and the Q9c will sit low enough to allow the mini usb to connect.
Search and Read and you shall find.........Fred
There's that pic again! Is that two regular spares or an extended? And it's not the 3200 right?
oh really ? so there is also a hardware difference between the various Q9's..
