Old 02-05-2008, 09:59 AM   #11 (permalink)
DrQ
DrQ's Avatar
DrQ is on a distinguished road
oh really ? so there is also a hardware difference between the various Q9's..
Yes sir, slight as it may be. That's why folks are buying the Verizon Q9M std door for their Q9C.
I got one on ebay and that won't sit in the cradle either. Even with a std battery, better life that my Q.
BTW RB did you catch my review?
http://www.everythingq.com/forum/mot...q9c-17199.html
Search and Read and you shall find.........Fred
DrQ is offline
Old 02-05-2008, 10:08 AM   #12 (permalink)
aha.... thanks for that nugget of info.
gonna read it now....
Old 02-05-2008, 10:24 AM   #13 (permalink)
Originally Posted by TreeFrog View Post
There's that pic again! Is that two regular spares or an extended? And it's not the 3200 right?
That is one battery, and I've no clue what size it is. I don't believe it's the 3200, as there is still room in the slot for a bigger battery. I picked it up, when I bought the Q. back in December 06. My good friend runs a VZ store, and I simply asked for a long life battery.
It doesn't suprise me that the Q's differ slightly in size and layout. I'll have to swing by my friends store to see if he has a 9m in stock so I can check it out. My upgrade is still 7 months out, so I'm hoping that Motorola comes out with a newer/revised Q before then. If not, I may hang on until xmas or the new year.
Contributions via PayPal? Yes, you can, it's my email address.
Nascar: Bumper to Bumper, 200 mph, 40 Professionals
Boston: Bumper to Bumper, 70 mph, 400,000 amateurs
Der Alta is offline
Old 02-05-2008, 10:37 AM   #14 (permalink)
TreeFrog's Avatar
Thanks..just making sure there wasn't an earlier model that supported a 3200! Mine's close but won't go..with some light dremeling or if I took the paper off the battery it would fit. Just didn't want to void any warrenties yet!
TreeFrog is online now
Old 02-05-2008, 06:40 PM   #15 (permalink)
sinclac is on a distinguished road
Originally Posted by grkul View Post
Does it have the slot to charge the extra battery? The picture on the site shows only the front. Thanks.
Yes it does.
sinclac is offline
