On the original Q, the speakers get plugged into the headphone jack, and the charger gets plugged into the usb port. If the Qh is the same, you can use the wall ac adapter to charge, and still plug in speakers. I have that set up right now.
Q is plugged into wall outlet charging, speakers are plugged in playing music, & I'm sitting in bed listening to the music & replying to you!
Hope this helps ;)
I missed the part about you wanting to sync also. I guess you could either synch using bluetooth, or with the usb cable into the pc. This would also charge the phone...
