Old 03-22-2008, 11:11 PM   #1 (permalink)
REDandBLACKpack is on a distinguished road
Default chargers/batteries
I currently have a moto q9c with the extended battery however sometimes I find that my battery does not last me the full day if I am using it alot so i am looking for another option. I am not normally in my car so a car charger probably wont be my answer but Im thinking of picking up another battery or possible some sort of device that will allow me to charge my phone on the go. Im not sure if i want another battery since I will have to charge it through the phone but maybe this would be fine. I saw on sprints website they sell a device that will give you about 2 full charges and you just plug your phone into it. has anyone used one of these? how well do they work? can you see how much power is left in it? Any suggestions?
REDandBLACKpack is offline
Old 03-22-2008, 11:28 PM   #2 (permalink)
iuse an igo charger
works great! and inexpensive
google search it
-Sent from my Q
Old 03-23-2008, 07:16 AM   #3 (permalink)
PacoJr67's Avatar
To the OP, if you're referring to the travel charger pack. yes I do have it. It contains a 2200 mAh battery, so it won't do two complete charges with the Q9c (unless you also have the standard battery like I do.) It does work well though.
PacoJr67 is online now
Old 03-23-2008, 12:53 PM   #4 (permalink)
do any of these use AA or such batteries to charge, I would think that would be better since those are often more readily available than a wall charger.
Old 03-23-2008, 01:00 PM   #5 (permalink)
mike250rs's Avatar
would a desk charger at work be an option?
figure it will get expensive buying disposable batteries all te time, may come out cheaper getting a second battery.
mike250rs is offline
Old 03-23-2008, 01:01 PM   #6 (permalink)
PacoJr67's Avatar
Energizer sells one that does (there are a few others as well)
I actually have both rechargeable one and the AA powered one, no real preference.
Old 03-23-2008, 01:02 PM   #7 (permalink)
no unfortunately it wouldnt. im a college student so im out on the go a lot. I wouldnt be buying disposable batteries all of the time but to have something that I could keep in my backpack for when Im not in my room or near a wall outlet would be good.
Old 03-23-2008, 08:39 PM   #8 (permalink)
yes
i use an igo charger
www.igo.com
(feels like deja vu)
works great and uses AA batteries
