Old 08-24-2006, 11:46 PM   #1 (permalink)
bavarian3 is on a distinguished road
Default Call me crazy....Speck Activesport case.
Speck has an activesport armband for the SLVR... but I am wondering if I could use the Q instead...Q dimensions: 117 x 64 x 12 mm SLVR: 114 x 49 x 12 mm
The obivous thing I am worried about is the width... but I wonder if there is room? Any input? I believe the ipod case would work but its a bit more...
bavarian3 is offline
Old 08-25-2006, 10:12 AM   #2 (permalink)
kertsman is on a distinguished road
If the active case is made out of something that stretches you might be able to pull it off. Otherwise, I don't think the Q will fit, 15mm is a pretty big difference.
kertsman is offline
Old 08-25-2006, 03:18 PM   #3 (permalink)
TAG1976's Avatar
TAG1976 is on a distinguished road
Definately a great idea, but it looks a little to snug to fit the Q..
-Tom
TAG1976 is offline
