Old 04-08-2007, 12:25 PM   #1 (permalink)
jpkjd is on a distinguished road
Question Belt Clip for Black Q
I went to the Verizon store to get the black plastic (rubberized) belt clip for the new black Q and was told that the black Q is slightly thicker than the silver model and Motorola does not make a belt clip that fits the black one. Can anyoneconfirm whether Motorola, Seido or anyone else makes a clip that specifically fits the Black Q (and ideally faces the Q inward)?
Thanks for any help!
jpkjd is offline
Old 04-08-2007, 07:49 PM   #2 (permalink)
MattB's Avatar
MattB is on a distinguished road
I use the sedio clip with my black Q and love it. I do agree that the silver is very slightly thinner, and that may cause a problem with the stock clips. I've had my Sedio for a month or 2 now and there is no sign of wear on my Q.
MattB is offline
Old 04-09-2007, 10:37 AM   #3 (permalink)
daniel is on a distinguished road
Send a message via AIM to daniel Send a message via MSN to daniel
my sedio clip puts wear on the edge above the camera
"poverty is a blessing in disguise; it teaches survival." - russell anderson
daniel is offline
Old 04-09-2007, 11:15 AM   #4 (permalink)
Stealth's Avatar
Stealth is on a distinguished road
Yep - I have the same one and its starting to wear a little bit also.
Sprint Moto Q user
Stealth is offline
Old 04-09-2007, 12:22 PM   #5 (permalink)
Pegleg is on a distinguished road
one of the sedio holsters is supposed to be used with a clear case. i have an ebay'd smoke case that barely fits my sprint q, and i hope that the sedio holster fits.
Pegleg is offline
Old 04-09-2007, 02:52 PM   #6 (permalink)
john1_83's Avatar
john1_83 is on a distinguished road
If you go to verizon and order the clip for the silver q and use it. that;s what i did and it works great. No problems and no extra wear and tear from the clip.
john1_83 is offline
Old 04-09-2007, 05:25 PM   #7 (permalink)
Stealth's Avatar
I like the Sedio since it holds the Q face in, I can sacrafice a little wear and tear at the top of my phone if my screen stays scratch free. Do the ones you speak of hold the Q face in?
Sprint Moto Q user
Stealth is offline
Old 04-09-2007, 06:09 PM   #8 (permalink)
john1_83's Avatar
yes the screen of my q faces in. it works great. and since the screen faces in there is no problems with the extended battery either. only the back o the phone is exposed. if the people at verizon give you crap because their system says that the clip isn't for the black q they are full of it. the lack and silver q's are the same size.
john1_83 is offline
Old 08-06-2007, 07:10 PM   #9 (permalink)
Penguin21 is on a distinguished road
Default Seido holster clip issue
I had the Seido holster clip too and loved the fact that it was easy to get in and out and allowed the Q to face inward with the extended battery. BUT the clip broke off after only 2 weeks!!!! granted, this was 1 week plus longer than the other 3 cheap holsters I purchased. I thought by spending more I would get better quality. This was not the case. (no pun intended)
I wear the Q on my belt and the holster gets caught on every chair, car set, etc. that I sit on. The clip gives way and breaks off. I am now looking for a better solution for the Q with extended 3200 battery. Any suggestions are welcome. I would like something with a nice quality clip that won;t break off and allows easy access to the Q. Thanks.
Penguin21 is offline
Old 08-06-2007, 08:55 PM   #10 (permalink)
lil_jimmy_norton is on a distinguished road
Maybe just stop walking into stuff?
lil_jimmy_norton is offline
