Old 04-22-2007, 09:19 AM   #1 (permalink)
tkkidd is on a distinguished road
Default 2gb miniSD works with q can not access through 2.0 usb
hello all,
i have a mini Sd card.
transcend 2gb mini with Sd adapter.
i formatted the card when i first got it.
then using usb 2.0 card reader Loaded some songs on it.
then i used the card with moto q.
i played the mp3, and installed couple of apps on it.
today i was tried to plug sd card into usb reader to load more stuff on it.
but windows xp scaned through autoplay and said
not formatted want to format?
it works great wit q ( still after the prompt)
what gives?
if i installed the programs on mini i can't use the usb reader?
thank you thank you.!!!!
tkkidd is offline
