Old 06-03-2008, 12:00 AM   #11 (permalink)
bamhm182 is on a distinguished road
Yeah, I thought about that and tried it, as well as edited my last post, sorry for the misunderstanding, I was thinking that he meant hold it down until the ear piece volume pops up.
bamhm182 is offline
Old 06-03-2008, 07:36 AM   #12 (permalink)
Corey H's Avatar
Corey H is on a distinguished road
Send a message via Yahoo to Corey H
Originally Posted by bamhm182 View Post
huh? I think we've got a misunderstanding.
The way I'm seeing it:
If you scroll up it makes everything loud and than you'd have to turn it back down so that you're ringtone's not super loud.
If you hit up on the d-pad while in WMP, it'd only turn up the volume for WMP and leave the ringtone at the right volume.
Oh, the error was on my end, I just found out that the wheel does the same thing as the d-pad.
actually bobby i think he is right the scrolls turns up everything the d=pad on WMP just controls the WMP......for the ringtone issue you could go to settings>profiles>then the profile im guessing your using is normal if not go to that one and choose menu > edit > then go to ring volume and you can set it from 1-loud
Team USA
" REDEEM TEAM "
Add upz!!!
myspace
face book
Corey H is offline
Old 06-03-2008, 08:15 AM   #13 (permalink)
ummm if you scroll up in wmp it has the same effect as pressing up on the dpad
bobby-n is offline
Old 06-03-2008, 02:21 PM   #14 (permalink)
Corey H's Avatar
right but your not pressing it in.....when you press it in that turns up the whole phone
Team USA
" REDEEM TEAM "
Add upz!!!
myspace
face book
Corey H is offline
Old 06-03-2008, 02:27 PM   #15 (permalink)
yeah im talking about just scrolling up in wmp will increase the volume in wmp ( the percent )
bobby-n is offline
Old 06-03-2008, 04:56 PM   #16 (permalink)
Yeah, but in the first fix, the person said push the wheel, so technically we had three different ways floating around.
bamhm182 is offline
Old 06-03-2008, 04:57 PM   #17 (permalink)
ok im done talking lol as long as the problems solved
bobby-n is offline
Old 06-03-2008, 05:03 PM   #18 (permalink)
lol, alright, sounds good, man you post back quick. I've just got 1 more thing to say, maybe to clear it up a little better.
PacoJr67's way: turn up the volume for the whole system by holding in the wheel until the volume menu pops up.
Originally Posted by PacoJr67 View Post
Hold in the scroll wheel until the volume menu pops up, adjust that to 100%. That should fix it.
bamhm182's way: turn up just WMP using the D-Pad
bobby-n's way: turn up just WMP using the scroll wheel
Our ways are the exact same, and turn up just WMP, but Paco's way turned up the whole system. So, sorry about the misunderstanding. I'm done talking too, so like you said, problem solved, convo over.
bamhm182 is offline
