Old 05-05-2008, 09:02 PM   #1 (permalink)
gstide is on a distinguished road
Default WIFI and GPS
I saw something about WIFI configuration in registry. Does Q9c support WIFI? then I can use it to connect to my home network directly!
GPS:
Q9c has GPS chip. But, how to use it? Is there any software can use this chip directly instead of buying a bluetooth GPS receiver?
Thanks.
gstide is offline
Old 05-05-2008, 09:03 PM   #2 (permalink)
BTW, WIFI here, I refer to 802.11. not bluetooth
gstide is offline
Old 05-05-2008, 09:04 PM   #3 (permalink)
no wifi use a wifi card
for gps use google maps or windows live search
-Sent from my Q
Old 05-05-2008, 10:03 PM   #4 (permalink)
Guardian's Avatar
-Sent from my Q
Curiosity question, doesn't the Q9h have a WiFi built-in that is locked out and 6.1 patch is supposed to unlock it but At&t is holding out for the time being. Anyone know if that is true and if so how to hack the unlock on it. Thanks in advance and don't blast me saying just search for it. Be nice and help a few Q-er
AT&T Motorola Q9h - Vista Ultimate AMD x64
Guardian is offline
Old 05-05-2008, 10:05 PM   #5 (permalink)
thats the rumor...but you know how that goes..
and no there is no hack...if there was it would have been all over this place
only time will tell once 6.1 comes out to see if its true or not
Old 05-05-2008, 11:27 PM   #6 (permalink)
-Sent from my Q
I may misunderstand you.
But GPS function I mentioned above is a chip or sth which can receive GPS signal, then locate the position of itself. not software like google maps.
I saw some GPS options somewhere in Q9c. I just cannot figure out how to activate it such that GPS software can use it to locate this device's posion and I don't have to buy a bluetooth GPS signal receiver.
...no one has more info about WIFI?
gstide is offline
Old 05-05-2008, 11:34 PM   #7 (permalink)
Guardian's Avatar
Sounds good, we will see then. If you come across the 6.1 for Q9h At&t, give me a holler please in case I miss it. Thanks.
Guardian is offline
Old 05-06-2008, 08:23 AM   #8 (permalink)
GPS is already built in to the Q9c so there is no need for an external receivedr. which is why i said use windows live search or google maps to utilize your GPS
you need a wifi card...plain and simple if you want to use your Q with a wifi connection
there is no other way
jgowrie (06-05-2008)
Old 05-06-2008, 08:29 AM   #9 (permalink)
PacoJr67's Avatar
deja vu
already answered the OP's question on the motorola forums
so I have nothing to add here, other than saying N99's right (and he knows it!)
I'm just sayin'
PacoJr67 is online now
Old 05-06-2008, 08:30 AM   #10 (permalink)
Originally Posted by PacoJr67 View Post
deja vu
thank you sir
