Old 04-08-2008, 06:36 PM   #1 (permalink)
matthewjohn's Avatar
matthewjohn is on a distinguished road
Default VITO CopyPaste problems?
I am unable to get the copy paste program to install. There is no .cab file on the DL site. I have DL the .exe file and ran it as instructed and given some win32 error. DL the .zip and did instructions with same result. What can I do? is there another program? This is the link to the program in question.
http://vitotechnology.com/en/product...ID=1867&BID=24
matthewjohn is offline
Old 04-08-2008, 06:39 PM   #2 (permalink)
TreeFrog's Avatar
just put the exe on your Q and then click on it to turn vito on..click again to turn off!
TreeFrog is offline
Old 04-08-2008, 06:40 PM   #3 (permalink)
copy the 2 files to the Q, execute there w/ the File Manager. (it is not an install)
potQ.
Old 04-08-2008, 07:02 PM   #4 (permalink)
OK got it copied and executed. It made a file VitoCopyPaste.exe.ini Now what do I do with that. I try and open it and it asks me with what program. I thought this was just going to be extra options in the edit functions and not a program you had to run every time you want to use it?
Old 04-08-2008, 07:48 PM   #5 (permalink)
mike250rs's Avatar
when you ran the program for ther first time it should have placed a .lnk file in your \windows\start up folder. this will start the program when Q is powered up.
mike250rs is offline
Old 04-08-2008, 08:42 PM   #6 (permalink)
no it does not make a link (at least did not for me)... check if it's running after you executed it.... if so press and hold the enter button for a few seconds in any edit "field" and the Vito menu will pop up.
potQ.
Old 04-08-2008, 08:44 PM   #7 (permalink)
oops... yes it does create a link in the Startup folder i thought you said Start Menu mike.. my bad.
potQ.
Old 04-08-2008, 09:25 PM   #8 (permalink)
It is running. Will it stay running or does it need to be reset? Also it did not put the .ini in the start menu. I moved it myself but it did not work, just asked for a program to use to open it, so I removed it from the start menu. Works good. A little different to figure out to use though. Thanks
Old 04-08-2008, 09:28 PM   #9 (permalink)
if it's not in the Startup folder it will not automaticlly start when you power cycle the Q.
potQ.
Old 04-08-2008, 10:03 PM   #10 (permalink)
the actual .exe file or the .ini?
