Old 04-08-2008, 10:05 PM   #11 (permalink)
neither, it should be a .lnk file...
potQ.
Old 04-08-2008, 10:16 PM   #12 (permalink)
matthewjohn's Avatar
matthewjohn is on a distinguished road
sorry, that's what I think i ment. Thanks
matthewjohn is offline
Old 04-08-2008, 11:22 PM   #13 (permalink)
mike250rs's Avatar
easy way....
highlight the .exe file using the file manager ) menu ) create shortcut
place the shortcut in the \windows\start up folder and you never have to mess with it again.
mike250rs is offline
The Following 2 Users Say Thank You to mike250rs For This Useful Post:
furball (07-10-2008), matthewjohn (04-09-2008)
Old 04-28-2008, 03:25 AM   #14 (permalink)
mexiken's Avatar
Ok. So after using this app, I've realized. It won't cut or copy anything that has already been written will it ???? In texts for example, it will highlight the persons name, and holding the button down brings up the contact info or call them. It works great when I've got a field to write in, but I can't just copy part of an email to a text can I ???? Thats a bummer if you cant.
mexiken is offline
Old 04-28-2008, 06:14 AM   #15 (permalink)
only "input/edit" fields... and even that not always unfortunately....
potQ.
Old 04-28-2008, 07:19 AM   #16 (permalink)
mike250rs's Avatar
you can reply to the email> hold down button and select highlight mode> pick the text> copy> cancel message then paste where needed
Sarcasm is free with your paid subscription to EQ!
Old 04-28-2008, 07:24 AM   #17 (permalink)
in most cases that works... but i was trying to copy which are edit/entry fields in Viigo to copy them into another app and no go, holding down the enter/action button only made the text move forward 1 position at the time :]
Old 04-28-2008, 07:28 AM   #18 (permalink)
mike250rs's Avatar
yep, ran into that same thing a few times. Deffinately not a perfect app, but it is better than nothing + its free
Old 04-28-2008, 08:29 AM   #19 (permalink)
absolutely agree...
Old 04-28-2008, 09:46 AM   #20 (permalink)
TreeFrog's Avatar
HookMgr should fix that little problem! I've been able to copy anything where i have the flashing cursor...
TreeFrog is online now
