Old 10-08-2007, 12:56 AM   #11 (permalink)
rasmith3530 is on a distinguished road
Make sure that if you modify the startup sound file, you back it up first. Whenever you mod, leave yourself a way back to stock! That's just in case your mod somehow backfires.
Sent from a laptop running Debian GNU/Linux
www.debian.org
Rob Smith
Moto Q with USCC
www.motorola.com
www.uscc.com
rasmith3530 is offline
Old 10-08-2007, 11:38 AM   #12 (permalink)
mwitzah's Avatar
mwitzah is on a distinguished road
thanks - I ended up adding a new file because startup sound file was protected & wouldn't let me modify or delete (i would've if I could've so I guess I lucked out doubly this way . . .)
mwitzah is offline
Old 10-24-2007, 09:56 AM   #13 (permalink)
sonorman is on a distinguished road
Default Make it STOP!!
Originally Posted by rasmith3530 View Post
I followed the hack for changing the startup sound to *none*, then decided that I would like to try using a different WAV file for the system startup. I copied the new WAV file to the Windows directory, and went in and pointed to the new file in the appropriate Registry Key, HKCU/Control Panel/Sounds/SystemStart. Upon power cycling the phone however, the new WAV file doesn't play. Is there some parameter that I'm missing? Do I have to rename the file to "piano.wav"?
Can you please tell me how you did that? I have been searching for a thread to get rid of the start-up WAV. Thanks in advance!!
sonorman is offline
Old 10-24-2007, 09:58 AM   #14 (permalink)
did you read the Hack Sticky?
sonorman (10-24-2007)
Old 10-24-2007, 10:33 AM   #15 (permalink)
piranah's Avatar
learned this the hard way wayyyy too many times
When you think you have had a bad day, just remember, somewhere in the world is the worlds' worst doctor, and somebody has an appointment with them tomorrow.
piranah is offline
Old 10-31-2007, 01:57 AM   #16 (permalink)
mwitzah's Avatar
I don't know if i'm missing something, but the hack thread doesn't fix this problem for the 9ms with updated windows v6 - I had a temporary fix but after a few days/weeks it no longer works. anyone with any suggestions on how to eliminate the start up sound on Q9 - we (i) need you!
mwitzah is offline
Old 11-04-2007, 01:24 AM   #17 (permalink)
personman is on a distinguished road
Default Had the same problem - try this
The hack didnt work for me either.
this is what i did:
I created a short silent wave file, named it vzw_startup_sound.wav ( i used windows sound recorder - turned off the microphone, recorded silence then deleted almost all of the original recording)
backed up the built in start up vzw_startup_sound.wav
copied the silent file over to my phone, then used 'copy to' in resco file explorer to copy my silent file over the default file.
you will get a prompt to overwrite and a warning about the danger of writing to rom. (i didnt have problems continuing, but you may risk damaging your phone apparently)
I restarted the phone... Ahhh silence... except then a little beep, damn, how do get rid of that? ehh, I can live with it.
personman is offline
Old 11-10-2007, 11:34 PM   #18 (permalink)
jespley is on a distinguished road
Default No sound file for q9m's
this is what i did:
So, I recorded a soundless file and replaced my vzw_startup_sound.wav with it. There is no beep or anything. It is just silence....\bliss
I'm making the zip file available below for anyone who wants to use it.
Here is what I did:
Using the explorer window via ActiveSync, I went to the \Windows directory (where the annoying vzw_statup_sound.wav resides) on the mobile device. I copied and pasted the original *.wav file to my desktop (as a backup) and replaced it with the new file included in this post. Now you too can enjoy the silence!
Good luck.
jespley is offline
The Following User Says Thank You to jespley For This Useful Post:
leonsb3 (11-26-2007)
Old 11-14-2007, 12:41 PM   #19 (permalink)
smiller2076's Avatar
smiller2076 is on a distinguished road
I edited the registry entry to *none* and I have blissful silence on start-up
Funny thing is, on my other Q that went FUBAR, I got the short (but less annoying) start-up sound after changing to *none*.
smiller2076 is offline
Old 11-19-2007, 04:29 PM   #20 (permalink)
jeehole is on a distinguished road
Here is what I did:
Good luck.
For some reason I cannot do this. I have a Moto Q9m from Verizon, and it has WM6. When i use active sync explorer to try to replace, delete, or rename the existing vzw_startup_sound.wav file it gives me a permission denied error.
I even tried it from file manager on the device, and when i try to rename it, it says "files in ROM cannot be renamed".
How were you able to do this? Am I missing something?
Thanks
jeehole is offline
