Originally Posted by Gadgetgeekman I not that computer savvy so that's why I decided to use the program. Are you familiar with it? Do I simply enter 65539 into the Glyph cache edit box and 4096 into cache size edit box? Thanks again |
yup you got it... its that simple.... the program is just the front man that edits the registry for you. as you said if you are not comfortable editing the registry yourself then the program is the safest bet...
Enjoy...
