Old 08-07-2006, 03:22 PM   #41 (permalink)
claypoolio's Avatar
claypoolio is on a distinguished road
not sure if the two are related, but i did this hack and the startup sound hack and now i can't sync with my home pc via usb.
claypoolio is offline
Old 08-07-2006, 04:10 PM   #42 (permalink)
tj!2k6's Avatar
tj!2k6 is on a distinguished road
Can you elaborate further on the definition of "can't sync" ?
tj!2k6 is offline
Old 08-07-2006, 05:54 PM   #43 (permalink)
claypoolio's Avatar
i plug in the Q with the usb cord and the little green icon turns green and spins around then nothing. I've done the error test and still nothing even uninstalled active sync 4.2 and reinstalled it. still nothing.
Old 08-07-2006, 05:57 PM   #44 (permalink)
tharmsen's Avatar
tharmsen is on a distinguished road
I haven't had any problems with the speed hack yet... it might be the other hack or the combination of the two. You might have to do a master reset to set things right if you can't get it working... or reset the values you altered.
tharmsen is offline
Old 08-07-2006, 06:30 PM   #45 (permalink)
tj!2k6's Avatar
Kind of a basic question, but did you try cycling the power on both your Q as well as your PC? I've had issues like you describe with previous PDAs and restarting the device as well as the PC usually took care of it.
I just applied the speed hack as well as the startup sound hack and have no issues syncing with my PC.
tj!2k6 is offline
Old 08-07-2006, 06:34 PM   #46 (permalink)
bmwbig6 is on a distinguished road
I applied the speed hack and noticed some improvement, and no ill side effects with either wireless or ActiveSync (yet).
bmwbig6 is offline
Old 08-07-2006, 06:46 PM   #47 (permalink)
claypoolio's Avatar
Yep, I've tried everything. I don't know what to do.
Old 08-07-2006, 06:49 PM   #48 (permalink)
tj!2k6's Avatar
A couple of other things you could try..
- un-do the registry hacks
- uninstall and reinstall ActiveSync on your PC
- make sure you're running the latest version of AS
- if you have another PC there, install AS on it and see if the same thing happens
Good Luck.
tj!2k6 is offline
Old 08-07-2006, 07:34 PM   #49 (permalink)
claypoolio's Avatar
well i reversed the speed hack and viola my Q now syncs up. I'm not sure what one has to do with the other.
Old 08-09-2006, 03:14 PM   #50 (permalink)
jramos is on a distinguished road
Default Access denied when modifying registry
Hi there. I believe my phone is app locked, and I cannot get it unlocked no matter what method I try (RAPI, AEConfig). I'm actually trying to install the .NET cf 2.0 and the CAB installation is unsuccessful. I tracked down the problem to not being able to change system files or modify the registry, which lead me to this thread. Unfortunately nothing seems to work. Has anyone run into this?
Many thanks!
José
jramos is offline
