Old 08-05-2006, 01:45 PM   #31 (permalink)
tharmsen's Avatar
tharmsen is on a distinguished road
Originally Posted by tymewillcome
MAn oh man...I wanna do this speed hack, but i cant find the darn registry changer with resco. I have Resco in the phone, I can open it, but I only have the options for an explorer. No registry Editor. When I installed it also, I never got the option of a registry editor....Please help me- I would love to be able to try this hack! thank you my fellow Q's
Ok, do the following.
1) connect your Q to your PC via the USB connector
2) open active sync and connect it to the phone (should automatically connect)
3) From Active Sycn nav click: Tools > Add/Remove Programs
4) You will see a list of programs you may add or remove in the next pop-up box
5) check Resco Registry Add-in (it won't be checked) and leave all others currently checked - checked
6) click "OK"
It will now install the Reg Edit on your phone. You will find it in your Start menu.
Let me know if this doesn't work.
EDIT: This screen shot may help of what you will see on your PC.
tharmsen is offline
Old 08-05-2006, 03:52 PM   #32 (permalink)
tymewillcome's Avatar
tymewillcome is on a distinguished road
Send a message via AIM to tymewillcome
thank you so much! Im still having a problem--sux-- My Q says that this was not intended for my device. The explorer installs, but the registry add in doesnt....Do you think Verizon locked this feature? Am I doing something wrong?
tymewillcome is offline
Old 08-05-2006, 04:23 PM   #33 (permalink)
claypoolio's Avatar
claypoolio is on a distinguished road
I just did this hack ,worked awesome.
claypoolio is offline
Old 08-05-2006, 08:11 PM   #34 (permalink)
sbagdan's Avatar
sbagdan is on a distinguished road
Make sure you are using the SMARTPHONE version on Resco, I had and Issue, there are (2) version of Resco, PPC and Smartphone.
Steven
Motorola Q
Ex-Crackberry User
sbagdan is offline
Old 08-05-2006, 11:21 PM   #35 (permalink)
Awesome, I finally figured it out! I installed an older version for smartphones. Does anyone think the values increased may affect the Q?
Old 08-06-2006, 03:30 AM   #36 (permalink)
Rhstevenson is on a distinguished road
So what exactly does this do to the q? What is it changing? Overclocking or something?
Rhstevenson is offline
Old 08-06-2006, 11:02 AM   #37 (permalink)
tharmsen's Avatar
The only problem I encountered was my IMPlus application locked up on launch after the changes. It was a trial version so I just uninstalled it. It may not be related to the hack... IMPlus has always been buggy software in my experience.
tharmsen is offline
Old 08-06-2006, 02:30 PM   #38 (permalink)
Arrow
I did the speed hack; i changed it to the 32000 number not the 64000. I'm not sure if i notice any difference yet, i think the screens load faster. Do people suggest moving up to the second number? I've seen both suggested and wanted to get someone's opinion. Thanks!
Old 08-06-2006, 10:14 PM   #39 (permalink)
r3tro is on a distinguished road
Originally Posted by taxl
So what is the directory path to the File?
What he said.
r3tro is offline
Old 08-07-2006, 12:57 PM   #40 (permalink)
tj!2k6's Avatar
tj!2k6 is on a distinguished road
Yeap, IMPlus definitely very buggy software, and I can't believe they advertise the current version as being compatible with the Q. 90% of the time is locks up my Q.
tj!2k6 is offline
