Old 09-18-2007, 08:58 PM   #111 (permalink)
ipsiloe is on a distinguished road
This is the best hack ever! my IE and programs work so much faster YEAH!!!
ipsiloe is offline
Old 09-24-2007, 05:49 PM   #112 (permalink)
reklisammy is on a distinguished road
help me out a litle bit here. where or how do I get to the hkey?
reklisammy is offline
Old 09-24-2007, 09:08 PM   #113 (permalink)
casemods's Avatar
casemods is on a distinguished road
What mobile registry editor do you have?
Please use Imageshack.us to post pictures, and help out people on low screen resolution or slow internet connection! Thanks!
casemods is offline
Old 09-24-2007, 10:40 PM   #114 (permalink)
acr4life is on a distinguished road
do these hacks work for the q 9m? are they WM6 compatible?
acr4life is offline
Old 10-07-2007, 05:07 AM   #115 (permalink)
wledvina is on a distinguished road
When I go int othe registry to do these hacks i go to
HKEY_LOCAL_MACHINE\SYSTEM\GDI\GLYPHCACHE
then I select values, then menu when limit is selected, and new value...then do I want to select String and enter 32768??????? It says to change it from 16384 to 32768 but I don't even see the 16384 in there to start with????
On the second one
HKEY_LOCAL_MACHINE\SYSTEM\STORAGEMANAGER\FATFS
I find CacheSize. Do I want to put 4096 in for the string value.
Sorry I am new to this sort of thing.
Thanks
wledvina is offline
Old 10-07-2007, 11:55 AM   #116 (permalink)
mbrevard's Avatar
mbrevard is on a distinguished road
Originally Posted by q-rocks View Post
I had the same problem and discovered this: Mobile Registry Editor will work.....but you have to do AEConfig first......read about it download it at http://www.breaksoft.com/Blog/Posts/...ditor_FAQ.aspx
Look for AEConfig.exe on the page....and follow instructions.....I did this a month ago and Mobile Registry Editor works like a charm for me now.
Alrighty. For those of you that are using Mobile Registry Editor the above link for the AEConfig zip does not work any longer. I was able to find it here. You have to download the whole UnlockAudioVox5600Apps.zip . Just extract AEConfig. To install follow these steps.
* Make sure you have ActiveSync installed and your phone connected via USB or serial port.
* Download AEConfig
* Unzip the file
* Copy the "Disable Security" shortcut in "Storage\Windows\Start Menu"
* Copy "AEConfig.exe" and "DisableSecurity.xml" in the "Temp" folder
* Now on your Smartphone run "disable security" from your phones start menu
* You should be prompted that it worked (might take a bit)
Mitch
My Blog
Twitter
Rockin The Q 9c With Verizon
mbrevard is offline
Old 10-11-2007, 05:12 PM   #117 (permalink)
xgrewellx is on a distinguished road
Make sure you have your computer set to view hidden files and folders.
while in windows explorer click Tools --> Folder Options.
Then click on the view tab then click the radio button that says: "Show hidden files and folders"
Also, not sure if this is specific to vista or not, but you need to also uncheck "Hide Protected Operating System Files"
I had to do that last one to get it to show up on my computer.
xgrewellx is offline
Old 10-12-2007, 04:01 PM   #118 (permalink)
Evan is on a distinguished road
question, i have the demo version, when it expires will the hacks still be in place and i will just be unable to use the program to edit them? or does it delete what i did...
Evan is offline
Old 10-12-2007, 05:52 PM   #119 (permalink)
WeldFire is on a distinguished road
Every thing should still be edited some things reset like the internet speed hack reset every once in wahile.
WeldFire is offline
The Following User Says Thank You to WeldFire For This Useful Post:
Evan (10-12-2007)
Old 10-12-2007, 05:57 PM   #120 (permalink)
sounds good thanks...one last question...the one area that i have noticed that my q9m is slow is when you type in a name (not going to the contact list) and then the numbers show up with the names under it. If you scroll down to a name and select "text", it takes a few seconds for the text to come up. I did the speed hack and it didn't really help the issue. Any idea?
this problem is just a little irritating since ill start typing and the text message box isn't up yet
Evan is offline
