Old 10-09-2007, 01:51 AM   #1 (permalink)
beargibs is on a distinguished road
Default PLEASE post original registry/picture resolution values
Can someone please, please post the original registry values for hkey\local machine\software/microsoft/pictures/camera/oem/picture resolution 1-5 values, the "low, normal, and high quality file size" to be exact. This is for a sprint phone btw. i would greatly appreciate it. i have screwed mine all up and i cant find the original values anywhere! thanks in advance! Or you can email them to me at 726682@gmail.com! keep up the hacks!
beargibs is offline
Old 10-09-2007, 02:48 AM   #2 (permalink)
Bobby Budnick is on a distinguished road
Alltel Q with MOL2 here. Should be the same if yours is an original Q.
1. high-7168 low-4096 normal-6144
2. high-9216 low-4096 normal-6144
3. high-17408 low-7168 normal-12288
4. high-56320 low-20480 normal-30720
5. high-204800 low-61440 normal-66560
Bobby Budnick is offline
The Following User Says Thank You to Bobby Budnick For This Useful Post:
beargibs (10-09-2007)
Old 10-09-2007, 03:23 AM   #3 (permalink)
Default thank you so much bobby! that was fast!
everythings working perfect again!
beargibs is offline
Old 10-09-2007, 07:27 AM   #4 (permalink)
Pony99CA's Avatar
Default Don't Change Registry Keys
In the future, when you work with registry keys whose values you may not remember, rename the value, create a new value with the original name and put the value you want in that. If things get hosed, just delete the new value and rename the old value back to its original name.
Steve
P.S. Don't forget to press the Thanks button for Bobby.
Silicon Valley Pocket PC
http://www.svpocketpc.com
Pony99CA is offline
The Following 2 Users Say Thank You to Pony99CA For This Useful Post:
beargibs (10-09-2007), xgrewellx (10-12-2007)
Old 10-09-2007, 11:17 PM   #5 (permalink)
pony99ca said i should press the "thanks button", but i dont see it when i try to post a reply? I am using m q to type this with an opera browser.
beargibs is offline
Old 10-09-2007, 11:27 PM   #6 (permalink)
Neermind im an idiot! I forgot to change my opera settings to "see as desktop computer" instead of handheld devive when i logged on. Also in reply to Mr. Pony, ; normally I'd make a backup of registry values but it was REALLY LATE and i completely forgot! Could someone tell me what the height and width values are for the aforementioned registry values in #"5"? I could swear there was morethan four resolution choices under camera options on my q, but now the highest it shows is 480 x 640? But in the registry there are 5 choices for resolution? Am i making sense?
beargibs is offline
Old 10-12-2007, 09:01 AM   #7 (permalink)
Pony99CA's Avatar
Default Image Resolution
Width = 1280
Height = 1024
Steve
Pony99CA is offline
The Following User Says Thank You to Pony99CA For This Useful Post:
beargibs (10-14-2007)
Old 10-14-2007, 10:02 PM   #8 (permalink)
thank you so much again!
beargibs is offline
