Old 11-09-2007, 09:24 PM   #1 (permalink)
smiller2076's Avatar
smiller2076 is on a distinguished road
Default Low handset speaker volume
It seems like the handset volume is too low. I have moved the slider all the way up, but it still seems too low. I usually use speakerphone, but only in private, as in public it's an etiquette issue .
I saw the hack for the volume, but it doesn't seem to work. I'd use a Bluetooth, but I can't find one that I like...
smiller2076 is offline
Old 11-10-2007, 02:38 AM   #2 (permalink)
MBK2's Avatar
MBK2 is on a distinguished road
Have you increased your system volumes for each profile under settings?
MBK2 is offline
The Following User Says Thank You to MBK2 For This Useful Post:
smiller2076 (11-10-2007)
Old 11-10-2007, 05:46 PM   #3 (permalink)
Is that what that setting is for? I thought it was for the system beeps...doh!
I had that completely turned off :P
Old 11-10-2007, 05:51 PM   #4 (permalink)
Hmmmm...that didn't work...still have low volume
Any other ideas? I really don't want to call Verizon again; this phone is a replacement from my other one that went FUBAR.
Maybe I should add that it's in-call volume that is too low.
Old 11-10-2007, 05:52 PM   #5 (permalink)
Did you hold in the Scroll button and adjust the main volume?
If you hold that in, and wait a few seconds, the main volume pops up and you can adjust the main volume.
Der Alta is offline
thegriff52 (11-10-2007)
Old 11-10-2007, 07:21 PM   #6 (permalink)
Yup...that's all the way up.
Old 11-10-2007, 07:24 PM   #7 (permalink)
MBK2's Avatar
So you went into Settings > Profiles > and then edited each profiles' volumes?
MBK2 is offline
Old 11-10-2007, 07:26 PM   #8 (permalink)
thegriff52 is on a distinguished road
I have tried 4 different times and actually went to Verizon to get the volume adjusted for the media player. Thanks. They only did the master reset Has anyone found out if we can download ringtones yet? I have tried Myxer tones but it will not work for Verizon , they have it blocked out. Oh and did I mention that they gave me the address...lol
thegriff52 is offline
Old 11-12-2007, 12:17 AM   #9 (permalink)
Wouldn't the settings only apply if you select that specific profile? I did edit the profile I use and turned everything to loud; speaker was still too low.
Old 11-12-2007, 12:29 AM   #10 (permalink)
I use my CD's and edit the songs for ringtones. This is one I use for my voice mail .
Use a sound editor and you can make whatever ringtones you want, as long as they are mp3 format.
