Originally Posted by thegriff52 I have tried 4 different times and actually went to Verizon to get the volume adjusted for the media player. Thanks. They only did the master reset  Has anyone found out if we can download ringtones yet? I have tried Myxer tones but it will not work for Verizon , they have it blocked out. Oh and did I mention that they gave me the address...lol |
The same thing happened to me as well, i ended up doing a master reset. BUT later on i found the problem, if you use another program, like VTAP for example(
www.vtap.com) and while your in that program, and you Decrease the volume, it also decreases the volume on the phone. I had the same issue, all i did is go into Vtap and increase the volume again. So MOST likely it was the same issue with a program you had installed. Verizon did a master reset because 101% of their members are retarded =)
Anyways hope this helped!
