Ok, so I updated my Ruttensoft Homescreen Designer and can now make landscape themes for Q. I have few questions concerning some plugins.
In the previous version there was an analog clock plugin, very simple in use and absolutely free. All you needed to do was to check both boxes 'use plugin' and 'install plugin'. In RHD 2007 you only have two options: either to download the trial from the third party website or not use the plugin at all. Plus, you need to insert a separate image for the clock, and in the prev. version you could draw it on your homescreen itself and it would be enough.
Another issue is the Wireless plugin. It says in a description that the developers are Microsoft, thus it is not a third part plugin, neither it needs to be downloaded. That assumes that I click 'use plugin' and it will be installed to my device together with the current theme. But no bluetooth icon is displayed, and no new layouts are availible at the Application Data/Home (I checked in case that was the way it had to be done)...
To cut the long story short, it's basicly two simple questions: what am I missing? (Analog Clock) and what am I doing wrong? (Wireless plugin)
Thanks
