Old 06-08-2008, 02:41 PM   #1 (permalink)
iam99x is on a distinguished road
Default Camera problem, should be easy fix??
Ok, so I was trying to remove the shutter sound using Mobile Registry Editor.
I deleted them instead of changing the registry like an idiot.
Now, when I try to open my camera, it doesn't do anything. So if I replace what I deleted, I should be fine.
So, could someone email me everything located in this folder:
\HKEY_LOCAL_MACHINE\System\Pictures\Camera\OEM\
I need everything in th OEM folder.
My phone is the Moto Q9h.
Thanks!
iam99x is offline
Old 06-08-2008, 09:31 PM   #2 (permalink)
Guardian's Avatar
Thanks!
Don't do it again.
File Type: zip Camera.zip (400 Bytes, 22 views)
AT&T Motorola Q9h Global 6.1 (Primary Device)
Guardian is offline
Old 06-09-2008, 12:49 AM   #3 (permalink)
Originally Posted by Guardian View Post
Don't do it again.
Ok, so I have the attachment on my computer. How do I get it on to my phone? It won't let me click and drag it into the Mobile Registry Editor program.
iam99x is offline
Old 06-09-2008, 02:34 AM   #4 (permalink)
Guardian's Avatar
Well I don't know what registry editor you are using but just about all of them have an import feature and you can select the file and done. If not, then use one that does, I have attached my favorite one which you can run from your desktop while attached to the device. good luck.
If you can't get any of that to work, then there is always the good old fashion way of putting them in there manually, good times.
Guardian is offline
Old 06-09-2008, 05:05 PM   #5 (permalink)
That's the one I have. I'm new to the registry editor. I can't figure out how to change the values on anything or add registries back. Help?
iam99x is offline
Old 06-09-2008, 05:31 PM   #6 (permalink)
Guardian's Avatar
Ok, Plan B then, let's see if we can make this simpler.
1. Extract and copy the attached regedit.exe file to your device along with the .reg file that I gave you earlier.
2. On your device, find it and run it.
3. Click on the "Menu" button
4. Click on "Tools" or #7
5. Click on "Import" or #2
follow the directions to find the .reg file and you should be done. Good luck.
Anyone else want to chime in with another solution? or assist?
Guardian is offline
Old 06-09-2008, 05:32 PM   #7 (permalink)
Thank you very much. I will try it when I get home tonight.
iam99x is offline
Old 06-09-2008, 08:43 PM   #8 (permalink)
This is what I'm looking at on my computer, I'm not seeing "Menu" or "Import" or anything like that.
iam99x is offline
Old 06-10-2008, 01:33 AM   #9 (permalink)
bamhm182 is on a distinguished road
Maybe you can do it this way. Download the attached file, than follow the instructions on there.OEM files.txt
bamhm182 is offline
The Following User Says Thank You to bamhm182 For This Useful Post:
iam99x (06-10-2008)
Old 06-10-2008, 01:39 AM   #10 (permalink)
Rating or review
OMFG I love you. Thank you guys so much! It worked!
WOOT!
iam99x is offline
