Originally Posted by iam99x What you just posted was a waste of time. I've thanked you already. In case you missed it, thank you for your effort. I know I was doing it wrong. An alternative method worked. No need to get upset...  |
How is that? Explain to me how a full .reg backup of the key and instructions to import them was a waste of time? I don't need the thanks, I just need to know how someone can waste someone's effort like this and now this? I am not upset and if doing it manually worked for you, good then maybe you should have done it that way by opening up the reg file I gave you and manually created the keys when I told you that not being able to use the regeditor you can do it that way. Wow, this is low and pathetic to be like this after I was the ONLY ONE who even tried to help you, primary reason why people don't help anyone anymore. You should be ashamed of yourself.
AT&T Motorola Q9h Global 6.1 (Primary Device)
