Originally Posted by kevdogg311 How do i rename it it? it will only save as .tgz or "all files" |
Choose All Files, and in the filename box add .cab to the end of the name. Or, if you've already saved it on your PC, just rename it to _____.cab (whatever the name of the file is).
