Originally Posted by Eugene There are 5 connection types: work, internet, etc. When you setup the wifi connection you have to associate it with one of those then in IE you can tell it to auto detect or manaully specifiy one of the 5. Then under the advanced menu you can also specify what is what. Auto also seems to start at the top of the list so you can accidently connect to evdo if you don't have everything set up right. |
Thanks. My wireless at my house is titled "default". I selected "edit" in the wifi menu and set "default" to an Internet Connection type.
Then I opened IE and selected options, and selected the Connection Type to be Internet as well.
Now does this mean when I'm connected to my "default" connection at my house it will automatically default to using Wifi? Im guessing if I wanted to set up another connection, say at school, I would have to redo these options the first time I connect to it, correct?
My most prominent question is if I set up my "default" connection correctly to use the Wifi network.
*EDIT* By the way, the "auto detect settings" option in IE is UNCHECKED.
