Originally Posted by rpd444 I have a Motorola Q9m that I want to put ringtones on from Myxer.com. The problem is that when I order the ringtone, it goes to my MMS folder. When I click on the message, it says that it will download shortly. When the new (presumably downloaded) message arrives, I open it and it is just blank, no sound plays, and no message is there which would allow me to save a sound or anything...it's as though the message didn't have a ringtone contained with it.
Am I just retarded or is there some setting I need to turn on or off which will allow the ringtone to be downloaded to my phone? Any help would be well appreciated!
RD |
I'm am having the same problem. Every time I receive the message it is blank. I have tried with several different ringtones and I have the same problem with each one.
I know how to set the sound to a ringtone so the other thread does not help. I just can not figure out why the sound file is not attached to the message that I get from Myxer.
Thanks in advance for any help that you can give!
