Old 06-24-2008, 09:13 PM   #1 (permalink)
j4pro2001's Avatar
j4pro2001 is on a distinguished road
Send a message via AIM to j4pro2001
Default Super Noob Needs HELP!!!
Hey whats up guys and girls. I just got my q9m yesterday its sooo slow. when i type it lags like crazy it sucks i seen the speed hack but when i go to HKEY_LOCAL_MACHINE\SYSTEM\STORAGEMANAGER\FATFS. There is no cachesize folder justcachefilt?? what do i do? thanks so much for the help!!!
j4pro2001 is offline
Old 06-24-2008, 09:17 PM   #2 (permalink)
PacoJr67's Avatar
try turning the predictive text entry off and clearing the Input history
go to start > settings > text input settings
also you may want to check out S-K-Tools (the lite version is free)
http://s-k-tools.com/index.html?sktools/m_lite.html
and welcome to EQ!
I'm just sayin'
PacoJr67 is online now
The Following User Says Thank You to PacoJr67 For This Useful Post:
j4pro2001 (06-24-2008)
Old 06-24-2008, 09:25 PM   #3 (permalink)
welcome aboard..
and don't expect too much from the speed hacks, I have done none & my Q is fine speedwise..
potQ9c
Old 06-24-2008, 09:32 PM   #4 (permalink)
PacoJr67's Avatar
I tried them on my old Q1 and didn't see any appreciable difference so I went back to the defaults. (and then my Q9c came with the "hack" values standard)
I'm just sayin'
Old 06-24-2008, 09:33 PM   #5 (permalink)
kogama's Avatar
kogama is on a distinguished road
welcome to Eq tehre are lots of ways to increase your speed no hacks involved
-disable infrared settings - connections - beams
turn of bluetooth when not using it
use key lock home key-space bar
settings - home screen - time out - never
disable evdo if your not using internet at all or your not a big fan of it
get candlelight - dims lcd screen - can be found on my apps page
use tcpmp instead of wmp
My Q apps
Im just on a long as vacation
kogama is offline
Old 06-24-2008, 09:39 PM   #6 (permalink)
Q9 doesnt have IR port...if it did it would save battery life
doesnt speed it up would probably save a tiny bit of battery if anything
how does this speed up the device?
again saves battery does nothing to speed up the device
save battery life mostly if you are in a bad area with no connection and always switching back and forth...might might speed up if you are not swtiching back and forth
saves battery life does NOT speed up the device
the new Q9's have smartbacklight and doesnt need candlelight and alot of people report major issues with candlelight
doesnt improve overall speed of the device
Old 06-24-2008, 09:39 PM   #7 (permalink)
PacoJr67's Avatar
umm, no candlelight for a Q9 (unless you disable the smart backlight, which does the same thing anyway)
I'm just sayin'
Old 06-24-2008, 09:39 PM   #8 (permalink)
I don't believe Candlelight works good on the Q9's + it has the smart backlight.
potQ9c
Old 06-24-2008, 09:44 PM   #9 (permalink)
kogama's Avatar
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHHHHHHHH HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHHHHHHHHHHHHH oooooooooops whats wrong with me!!!!!!!! i maxed out my Q's battery life so much i didnt even realize what i was posting!!!!!!!!!!!!!!!
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!AAAAAAA AAh!!!!!!!!!!!!!!!!!!!!! thats my bad but itll help you with battery life..
also i didn't know these things about the new Q's since i have the original
My Q apps
kogama is offline
Old 06-24-2008, 09:46 PM   #10 (permalink)
PacoJr67's Avatar
don't feel too bad, rb was in your shoes not too long ago...
I'm just sayin'
