Originally Posted by firecracker37 The slownes is not normal, and here are a few suggestions:
Make sure you have killed open applications in the task manager, this is main cause of slowness IMHO.
If you recently changed your homescreen, ty pickng a different one. sometimes mistakes in the XML can slow down the device.
If the meory on your phone is almost full, try moving some apps or files over to a storrage card.
If none of those fix the problem, let me know and we will troubleshoot some more. |
Actually, I had a very similar problem. I would be typing and all of a sudden the characters would stop appearing. My phone was slow as well and I was constantly restarting it. Someone else on the forum suggested that I clear the buffer for the "predictive text". Well, I don't use that anyway so I cleared it and turned it off. My phone has been screaming fast since last week when I did that.
Start -> Settings -> (3rd screen) Text Input Settings - > Menu -> Clear Input History.
There are also other settings there to turn it on or off, how many characters before a suggestion, etc. If you use the function, try just clearing the history. Like I said, since I did that, my phone has been like brand new.
