Originally Posted by RetroHarley So I want to add the alarm clock as a speed dial but can not find the alarm clock application listed anywhere.......
The only place I can find it is in Settings/Clock and Alarm/Alarm but no place to add a speed dial.
Thanks. |
I don't think you can do this with the built in alarm. That being said it might be just as well as some have reported that the built in alarm has a negative effect on battery life. Most suggest a third party app which would be available as a speed dial. Many are free while some of the more sophisticated cost a small fee.
I use a couple of free ones: CTalarmclock Lite and AlarmMaster Beta.
A quick search will find a lot of these...good luck.
