Spectech's microSD WLAN Card Note this is regarding the micro and not the mini sd wlan card from Spectec.
After sending them an email with a couple questions I recieved this surprisingly gramatically correct email back. Took a couple weeks but still really awesome to hear back. Dear Timothy, Thank you for your interest. When will the microSD WLAN card be available? 1. It might take another 3 months to enter the market. What is the size of the microSD WLAN card compared to the typical microSD card? 2. A little longer than microSD WLAN card because the antenna is inside the WLAN card. Will the microSD WLAN card be compatible with the Motorola Q? 3. I would like to recommend you to buy our miniSD WLAN card (SDW-822/825) for Moto Q9m. Because miniSD WLAN card is available and price is cheaper than microSD WLAN card. Please note we have two versions of miniSD WLAN card. One is standard version for general models and the other is Moto version for Moto Q8/Q9m/Q9c only. Where is your location? I can send you our reseller info to ensure you buy the correct version if needed. Feel free to contact me if you have any questions. Best Regards, Justin Chen
Hope this was helpful to everyone!
I make phone calls on my Moto Q 9m
MTFBWY
