Old 03-06-2008, 10:56 PM   #31 (permalink)
Originally Posted by wittmer9m View Post
how do i go about using registry editor
download one
install it and find the key that the hack points to
if you need help using the actual program there are user guides of the program from the developers site where you downloaded it
i use total commader (its free)
Old 03-07-2008, 06:00 AM   #32 (permalink)
Weapondrift's Avatar
Weapondrift is on a distinguished road
This is a link to Resco Registry Editor.
http://www.resco.net/downloads/cab/r...eren_s.ARM.CAB
Plug your phone into your computer (which should open ActiveSync) Open the Link below from your computer, Your phone should do one of two things; (its been so long since I downloaded this ive forgotten)
1) It will say something like are you soure you want to download this to your phone. Click YES and warning will pop up. (this is normal) Ignore the warning by clicking yes. It should install the program. OTHERWISE read step two
2) plug in your phone to the computer which should open activesync. Download the link and save it to your computer. go to the desktop on your computer and right click and create a new folder. Type in Resco (or whateer you want that you can remember) After everything from this link has been downloaded on your computer, go to Start and find the Resco. copy the files from resco and paste these files in the folder that you just created. Right click on the folder and click Send to Device. Ignore the warnings and install everything its asks for and congrats you have a Reg Editor.
He who fights with monsters should look to it that he himself
does not become a monster…when you gaze too long into the abyss,
the abyss also gazes back."
-Friedrich Nietzsche
人生すべてのお別れをしている
- Life, is all about goodbyes -
Weapondrift is offline
