Old 05-01-2008, 08:37 PM   #1 (permalink)
ElephantGrl is on a distinguished road
Default Problems With E-Mail
I've got my Q set up to receive e-mails from my GMail account, and it sends/receives them just fine. However, as soon as I read an e-mail it automatically gets deleted. Is there a reason that happens and is there a way to make it stop happening?
ElephantGrl is offline
Old 05-01-2008, 09:45 PM   #2 (permalink)
rainmakerrc's Avatar
Are you using POP3 or IMAP settings? Try the IMAP settings. Instructions are on the Gmail website.
Rob
Apps on my Q9c
rainmakerrc is offline
Old 05-01-2008, 09:53 PM   #3 (permalink)
I am using POP3. Could that be the problem? I'll give you suggestion a try though...
Old 05-01-2008, 09:55 PM   #4 (permalink)
IMAP is also better because you can sync folders.
Rob
Apps on my Q9c
Old 05-01-2008, 10:02 PM   #5 (permalink)
Oh? How do you do that?
By the way, I set up a Gmail as an IMAP account and it's working perfectly...thanks!
Old 05-02-2008, 08:37 AM   #6 (permalink)
You're welcome.
To sync folders, open up your Gmail inbox on your Q and go to menu-->folders, then menu-->manage folders. Then you can choose which folders you want to sync. If you want to see the emails you send from your Q, be sure to sync the folder named "Sent Mail" (as opposed to the default "Sent Items" folder), and if you want to see the emails you delete, be sure to sync the folder named "Trash" (as opposed to the default "Deleted Items" folder).
Rob
Apps on my Q9c
Old 05-06-2008, 11:33 PM   #7 (permalink)
Ubie kid23 is on a distinguished road
How do I add my hotmail account to my email accounts. I purchased Pocket MSN from Microsoft & had it on my Q. I did not save the and had to perform a hard reset, resulting in losing the program. I can find anywhere on the net where to get the program again... it's very frustrating.
Ubie kid23 is offline
Old 05-07-2008, 08:47 AM   #8 (permalink)
Can you not download it from where you got it the first time? Maybe someone here will have the CAB for you. I have the CAB for Windows Live on my apps page, but the version I have does not have MSN Messenger (though it will allow you to put your Hotmail back on your Q). Don't know if that's a dealbreaker for you.
Rob
Apps on my Q9c
Old 05-07-2008, 08:50 AM   #9 (permalink)
Tony Bag o Donuts's Avatar
A bit late, but google actually wants you to use imap
My photography website.
leave comments, etc.
Tony Bag o Donuts is offline
Old 05-07-2008, 01:52 PM   #10 (permalink)
The Microsoft website I ot it before has changed. Now it says I can purchase it from Handango, messanger is not a deal braker... I rarely use it. Ill have a look @ your cab, thanks
