Old 03-12-2008, 08:13 AM   #1 (permalink)
wittmer9m's Avatar
wittmer9m is on a distinguished road
Default Phone Freezes at Verizon Wireless Screen
someone, if you could shed some light, i noticed some of my contacts were gone today so i soft resetted my phone to see what if would do, after i tried to turn it back on, it freezes at the verizon wireless screen! help
wittmer
wittmer9m is offline
Old 03-12-2008, 11:29 AM   #2 (permalink)
jmaynard1986's Avatar
jmaynard1986 is on a distinguished road
Send a message via AIM to jmaynard1986
Was your battery super low? If so, you may just need to let it charge a bit...
If the battery was good then I don't know what it could have been however, not to get u upset, but the only cure I have ever found was a Master Reboot...
(on Q)
jmaynard1986 is offline
Old 03-12-2008, 09:39 PM   #3 (permalink)
wittmer9m's Avatar
how would i go about a master reset when i cant even get my phone to pull up?
wittmer
Old 03-12-2008, 09:46 PM   #4 (permalink)
press and hold Power Key and the center d-pad button until a "DOS" STYLE SREEN COMES UP ASKING IF U WANT TO master Reset...
NOTE: u WILL loose everything!
The Following User Says Thank You to jmaynard1986 For This Useful Post:
wittmer9m (03-12-2008)
Old 03-20-2008, 09:17 PM   #5 (permalink)
ward6923 is on a distinguished road
this is the exact problem i had today, wish i would have read the board before making the trip to verizon, the guy did this reset, and my phone booted up right away, although i did loose everything as said. it works thought!
ward6923 is offline
