Old 03-15-2008, 07:15 PM   #1 (permalink)
wittmer9m's Avatar
wittmer9m is on a distinguished road
Default Help With Total Commander
okay so i had to get a replacement phone, and on my last one i used total commander....now i have a complete brain fart i downloaded it using a CAB this time and its not like before but i remember before i downloaded the .exe version and it gave me instructions as to where to drag some of the files when i extracted it,....im completely lost and need some help. please someone help!
wittmer
wittmer9m is offline
Old 03-15-2008, 07:29 PM   #2 (permalink)
copy the .cab to Q, execute it with the File Manager.
potQ.
Old 03-15-2008, 09:53 PM   #3 (permalink)
wittmer9m's Avatar
but is the cab file the one i want?
wittmer
Old 03-15-2008, 10:01 PM   #4 (permalink)
yes use the smartphone cab
-Sent from my Q
Old 03-16-2008, 08:12 AM   #5 (permalink)
wittmer9m's Avatar
okay now i need help with disabling the info for message sent
wittmer
Old 03-16-2008, 10:46 AM   #6 (permalink)
jmaynard1986's Avatar
jmaynard1986 is on a distinguished road
Send a message via AIM to jmaynard1986
Well you can either read the Official Hack Thread or go to http://mq.roeiboot.com/apps/ and get the NoMsgSentHack via .cab file....
*Search is your best friend*
*SEARCH is your best friend*
jmaynard1986 is offline
Old 03-16-2008, 11:01 AM   #7 (permalink)
just follow the steps in the hacks thread and then reboot the Q
