Old 10-21-2007, 05:45 PM   #1 (permalink)
prepboy1818 is on a distinguished road
Default help please
i first got my Q9m in September
since then i've had to get it replaced 3 times
this is the third time and its starting to do the same things the other ones did
its freezing, when i try to text someone it types a few words then it goes blank but i cant still type
volume is messed up, and calls ring once then goes to voicemail
what should i do?
reset or just see if maybe i misplaced something?
prepboy1818 is offline
Old 10-22-2007, 09:54 AM   #2 (permalink)
OceanQ9m's Avatar
OceanQ9m is on a distinguished road
what should i do?
Those are pretty unique problems to have happen in 3 different phones. I'd start by asking what kind of third party software are you loading on it?
As crazy as this sounds there is always that possibility that if you are getting your Q9m's from the same place each time that you could in fact be dealing with a batch of defective units. Maybe return it once again but get your replacement from another location? Online?
E
OceanQ9m is offline
Old 10-22-2007, 12:50 PM   #3 (permalink)
Default thanks
thanks so much
yeah i think its the place...even though its the verizon store...
hmm...idk
i reset it last night and its still a little slow and freezes sometimes
it might've just been the tcmp player + flash video software i downloaded for it even though i havent seen other posts saying they've had problems
Old 10-22-2007, 12:54 PM   #4 (permalink)
indcmb is on a distinguished road
Default Maybe a virus
The issues your having sound odd. My thoughts are maybe you have a virus.
indcmb is offline
Old 10-22-2007, 03:09 PM   #5 (permalink)
xtian63's Avatar
xtian63 is on a distinguished road
Send a message via Yahoo to xtian63 Send a message via Skype™ to xtian63
if u have ur own microsd or minisd and not use the 128mb that came with the package on all 3 units the problem may be in the memcard either a virus or file causing errors when accessed
back in the day i had my old Smartphone and PPC both were having issues with a specific picture file that when the units scanned the memcards(for example program files for an installed app that was placed in the memcard to save space) both of my WM devices froze, when that files was removed from my memcards the problem went away
From the 1st and original Windows Mobile SmartPhone:
HTC Tanager
(in the form of Smart Amazing Phone)
to the 1st 2.8" 320x240 PDA:
HTC Magician
(in the form of O2 XDA II Mini)
to Motorola's multimedia Smartphone:
Moto Q9M
xtian63 is offline
