Old 07-02-2008, 04:40 PM   #11 (permalink)
kogama's Avatar
kogama is on a distinguished road
the upper level, where you see all the directories... that's the root, so NO \Windows.. 1 "level" higher.
thanks bud.........
My Q apps
Im not crazy!!!! - Forum Policies
Its never to late to say hi..take a look at my Q apps
kogama is offline
Old 07-02-2008, 04:42 PM   #12 (permalink)
shoedoc is on a distinguished road
its got 2 be somethin im doin wrong..because I rightclick and send my cop of pim from my CPU to the root, and restart, letting it sit for abou 15-20 sec. then start back up and still nothing..
shoedoc is offline
Old 07-02-2008, 07:09 PM   #13 (permalink)
as I said before, copy it from the pc to a temp directory.. THEN copy it from there to the root, then restart.
potQ9c
Old 07-02-2008, 07:47 PM   #14 (permalink)
ohh ok i gotya.. so what does it mean when I do all of that. and then once i attempt to restart its stuck on the windows mobile screen..
edit** nvm I had to use one of my other copies of pim.. but shit works now, thx a ton!
shoedoc is offline
