Old 03-23-2008, 11:24 PM   #11 (permalink)
Originally Posted by kiel2309 View Post
Ok cool. I got the John knight guys themes figured out but the Eko guy i cant because there are more options and i dont know how to set those.
just move the file to the Q and install it
eko (her) themes are .cab files and will install
do not unzip her themes
some of her other themes have other program plugin and wont work unles you have those programs installed
Old 03-24-2008, 12:27 PM   #12 (permalink)
kiel2309 is on a distinguished road
On knights once i bring them up there are just two documents connected and i unzip and put them in my home folder for the q..
So just drag all of those files like 4 or 5 or whatever to the home application?
Will they copy and paste directly off the page that immediately pops up after the download ?
kiel2309 is offline
Old 03-24-2008, 12:29 PM   #13 (permalink)
huh?
take the .xml file and the .jpg and move them to the '\application data\home' folder
then go to
start
settings
homescreens
and find the name of the screen you just moved over
leave background as default and color scheme as default
Old 03-24-2008, 12:33 PM   #14 (permalink)
Im sorry that was confusing.. Im talking about if there are two .xml files?
Paste both of them to the '\application data\home' folder ?
kiel2309 is offline
Old 03-24-2008, 12:38 PM   #15 (permalink)
if there are 2 xml files verify that the file you downloaded was either a zip or a cab file
if a cab file then do not extract the files and move the ENTIRE file to the Q and execute the file using the file manager
