Old 07-05-2008, 02:23 PM   #1 (permalink)
wolfhound89 is on a distinguished road
Arrow Going from cable synch to wireless
When I first purchased my Q I did not get the data package. I would make my calendar changes and respond to e-mails and when I got home just connect it to the cable and away it went.
Well, today I broke down and get the data package. Now the questions are this.
Does wireless synch only handle e-mail or can it synch all of my Outlook data?
Since I had to create a new account on my Q do I keep the other account as it has all my folders and Outlook data?
Thank you.
wolfhound89 is offline
Old 07-05-2008, 02:29 PM   #2 (permalink)
you can sync from Q to pc and vice versa without a data plan..
potQ9c
Old 07-05-2008, 02:34 PM   #3 (permalink)
sherri's Avatar
sherri is on a distinguished road
Send a message via AIM to sherri
I didn't know Outlook could sync wirelessly. What carrier do you have? Verizon has wireless sync for calendar and contacts. Dashwire has wireless sync for contacts/internet favorites/pictures/and texts.
sherri is online now
Old 07-05-2008, 02:34 PM   #4 (permalink)
sherri's Avatar
potQ9c
Wirelessly? Would you need bluetooth on the pc? See, over a year here and I'm still a newbie! ;)
Old 07-05-2008, 02:49 PM   #5 (permalink)
yup you would need bluetooth on the pc inconjunction with active sync
-Sent from my Q9c
Old 07-05-2008, 07:55 PM   #6 (permalink)
If I can only do email while I am on the road that is fine. I am just trying to get my hands wrapped around the whole situation. If I make changes to calendar and contacts on my Q I would then have to synch via USB . If this is true then I am also fine.
Old 07-05-2008, 07:57 PM   #7 (permalink)
well if you use active sync you can do bluetooth and sync any item in the active sync menu
or if your pc doesnt have BT then you would have to use the cable
Old 07-05-2008, 11:45 PM   #8 (permalink)
Thanks for all the posts. I guess that when I make changes in outlook I will have to use the USB cable.
However, now I have two inboxes on my Q. One the synchs via cable and one wirelessly. So, is there a way to do it wirelessly and keep my outlook folder structure?
