Old 10-17-2007, 12:10 AM   #1 (permalink)
gmb1994 is on a distinguished road
Default Can't hear audio track when playing audio or video files
Although I'm able to hear phone conversations just fine, I have not been able to hear the audio track of any audio or video files using any of the media players (Windows Mobile, TCPMP, PocketTV). I even tried listening with a wired headset. Any ideas?
Notes:
1) I had previously installed and un-installed ... http://www.pockettv.com/ ... it just kept crashing on me.
2) I currently have installed ... TCPMP + AAC plug-in and Flash Bundle
gmb1994 is offline
Old 10-17-2007, 07:32 AM   #2 (permalink)
RetroHarley's Avatar
RetroHarley is on a distinguished road
I know this may seem like a silly question, but what does the volume indicator say in the bottom right corner of WMP? I used the arrow keys on the front of the phone to turn the volume up and down.
RetroHarley is offline
The Following User Says Thank You to RetroHarley For This Useful Post:
gmb1994 (10-17-2007)
Old 10-17-2007, 07:43 AM   #3 (permalink)
MBK2's Avatar
MBK2 is on a distinguished road
Notes:
Taking it for granted that you have set all the system volumes to desired settings...eg.> system volume, headset volume, speakerphone volume, etc...
TCPMP has a setting under 'audio', called 'preamp'...increase or decrease. That will help boost the audio I'm sure...
MBK2 is offline
The Following User Says Thank You to MBK2 For This Useful Post:
Old 10-17-2007, 09:42 PM   #4 (permalink)
It is set to maximum volume on the default verizon screen.
gmb1994 is offline
Old 10-17-2007, 10:30 PM   #5 (permalink)
Ok, that did it ... I didn't know about the master volume control located by pressing and holding the thumb scroll wheel for several seconds ... apparently, it overrides all other volume controls and I already had all other volume controls set to maximum volume. Thanks for the tips.
Note: The system volume (pressing and holding the thumb wheel) overrides the media player volume keys.
~Source: page 97 of the user's guide
Last edited by gmb1994; 10-17-2007 at 10:36 PM. Reason: Added link to user's guide
gmb1994 is offline
The Following User Says Thank You to gmb1994 For This Useful Post:
criticman (11-09-2007)
Old 11-09-2007, 09:47 PM   #6 (permalink)
criticman's Avatar
criticman is on a distinguished road
Thank you! I was going insane! I took the time to trim down an MP3 to be an excellent ringtone and went to play it...nothing. Then tried playing the Fergie video (lame) that came on the SD card and it no longer had audio. Glad it was something simple I overlooked!
criticman is offline
