Old 01-28-2008, 12:02 AM   #1 (permalink)
TechMedik is on a distinguished road
Default The built in alarm won't work right
So I use the built in alarm on my cell when I travel and stay in hotels.
On Friday I had it set for 8:20am and it went off just fine. I believe it hit the dismiss button and it turned itself off. When I got up, I went into the settings and turned the alarm off so it wouldn't repeat itself.
Even though I have it set now for 6:30am, it still goes off at 8:20am. I cannot figure out how to fix it.
Short of doing a reset, how do I turn off the damn alarm??
Also what is a good 3rd party alarm program to use in place of it so I can do multiple alarms?
TechMedik is offline
Old 01-28-2008, 01:16 AM   #2 (permalink)
TreeFrog's Avatar
Get SKtools lite..run the Notifications Queue and delete the 8:20 alarm...hopefully.
I think CT alarm is free? I roll with Gentimer..works great!
TreeFrog is offline
Old 01-28-2008, 10:50 PM   #3 (permalink)
It took a little while to figure how to use sktools but it worked. Thanks so much.
Old 01-28-2008, 11:31 PM   #4 (permalink)
TreeFrog's Avatar
Good deal!!
TreeFrog is offline
