Old 05-07-2008, 05:29 PM   #1 (permalink)
Duke4062's Avatar
Duke4062 is on a distinguished road
Default Setting Storage card as default storage Location?
Hello, does anyone know how to set the micro sd as the defaut storage location for music & pics? Right now everything gets saved to the internal memory even though I have a micro SD card in the Q9H?
Another semi related question. I was under the impression the Q9H accepted 8GB cards? When I go to format a 8GB Micro SDhc card I have it says "Over 4GB" and wont let me format it?
Fashion Phone: MOTORAZR 2 V9, Business Phone: Q9 Global
Duke4062 is offline
Old 05-07-2008, 05:36 PM   #2 (permalink)
Fire up the Q's camera or video function. Hit Menu>9. Options> highlight the Camera option and select it, and it will give you an option to change where to Save files to: (select your Storage Card) and remember to hit Done and not just exit out.
~maria
LuvrGirl is offline
Old 05-07-2008, 05:46 PM   #3 (permalink)
ninjaap's Avatar
I remember others posted getting this message: "over 4gb". But they claimed that they were able to go ahead with the format.
ninjaap is offline
Old 05-07-2008, 05:56 PM   #4 (permalink)
Duke4062's Avatar
~maria
Thanks but how about for music? All my music ends up in the internal memory too?
Duke4062 is offline
Old 05-07-2008, 06:02 PM   #5 (permalink)
Duke4062's Avatar
It will not allow me to format it?
Another strange thing is When I go to main menu>system tools>memory manager I can fully view the card, it says storage 7.60GB, free 7.60GB. But when I go to Main Menu>My stuff>Storage card, it says "No storage Card Found". This is also true of the 2GB card. Is my Q defective or something?
Duke4062 is offline
Old 05-07-2008, 06:15 PM   #6 (permalink)
U-2
U-2 is on a distinguished road
Had the same problem when I inserted the card the first time. Reboot helps.
U-2 is offline
Old 05-07-2008, 07:01 PM   #7 (permalink)
Duke4062's Avatar
Thanks that fixed that issue.
Still no luck on formatting the 8GB card or setting the storage card as default location for music storage?
Duke4062 is offline
Old 05-07-2008, 07:15 PM   #8 (permalink)
Try formatting it on a PC if you can. Also, you need to simply drag the music there instead of on the phone when coming from the PC. From a browser, there should be an option to hit "Save As" or something
mexiken is offline
Old 05-07-2008, 11:23 PM   #9 (permalink)
Duke4062's Avatar
I wouldnt know how to format it on a Pc. Would that even format it correctly?
Well I blutoothed over some music and it ended up in the internal memory?
Duke4062 is offline
Old 05-07-2008, 11:45 PM   #10 (permalink)
U-2
I have 8Gb card. I did not have to format it - it is sold already formatted. If you need to format it anyway, put it into the reader and format it as FAT32.
Another question - why do you need to bluetooth the music over? I copied what I wanted on the storage card using SDHC card reader http://www.ledshoppe.com/Product/com/CA2029.htm (4x-8x times faster than via USB cable)
U-2 is offline
