Old 05-08-2008, 03:55 AM   #11 (permalink)
ninjaap's Avatar
Originally Posted by Duke4062 View Post
It will not allow me to format it?
Another strange thing is When I go to main menu>system tools>memory manager I can fully view the card, it says storage 7.60GB, free 7.60GB. But when I go to Main Menu>My stuff>Storage card, it says "No storage Card Found". This is also true of the 2GB card. Is my Q defective or something?
Since the memory manager recognizes how much storage space the sd card has, doesn't that mean that it's already formated? Why don't you try transferring a file such as an mp3. Then use file manger to open the file. If it opens then everything is good. Just being able to transfer a file into the card should mean it's formatted.
ninjaap is offline
Old 05-08-2008, 04:06 AM   #12 (permalink)
mexiken's Avatar
I wouldnt know how to format it on a Pc. Would that even format it correctly?
Well I blutoothed over some music and it ended up in the internal memory?
Yes it would format correctly. But it should be formatted already.
And you need a Bluetooth manager app if you want to manage where you save files. If not, they will automatically save to my documents.
mexiken is offline
Old 05-08-2008, 12:34 PM   #13 (permalink)
PM/email me if you want a Bluetooth manager app that will make your default "save to" location be your storage card.
I'll email you the app I have on my Q.
~maria
LuvrGirl is offline
Old 05-08-2008, 01:30 PM   #14 (permalink)
Guardian's Avatar
Yes it does mean that it is formatted.
AT&T Motorola Q9h Global 6.1 (no longer my primary device)
Icon provided courtesy of Manbat's son!
Guardian is offline
Old 05-08-2008, 01:31 PM   #15 (permalink)
Guardian's Avatar
Since we are on the subject of storage, can anyone tell me how to get Outlook to save all the attachments on the SD by default?
Guardian is offline
Old 05-08-2008, 01:38 PM   #16 (permalink)
mexiken's Avatar
I've never found such a way. Let me know if you do though. That would rock.
mexiken is offline
Old 05-08-2008, 01:39 PM   #17 (permalink)
mexiken's Avatar
~maria
By chance, whats it called ???? Cuz I've tried a few on the Q Global that are supposed to work because they worked on the Q, but no dice
mexiken is offline
Old 05-08-2008, 02:41 PM   #18 (permalink)
ninjaap's Avatar
~maria
Could you post that here please, for everyone else to see?. Im interested too.
ninjaap is offline
Old 05-08-2008, 03:20 PM   #19 (permalink)
Yup, I can
I did this on my Q9 Global with AT&T and it works perfectly!!!
** MOVE EMAIL & ATTACHMENTS TO STORAGE CARD **
Updated for Windows Mobile 6!
1) Using the file manager in activesync, create the following folders on your Storage Card.
\MAPI
\MAPI\ATTACHMENTS
You can actually name them whatever you want, "Inbox" for example.
2) Now browse to \Windows\Messaging (SmartPhone)
If you want to save all of your existing mail, move everything in this directory to the new ones on your Storage Card.
3) Now fire up your registry editor and navigate to the following.
For WM5 Phones: [ HKEY_CURRENT_USER\Software\Microsoft\MAPI ]
For WM6 Phones: [ HKEY_LOCAL_MACHINE\System\Inbox\Settings ]
Then create the following STRING VALUES:
String: \Storage Card\MAPI\Attachments
4) Reboot your phone and then goto your inbox. If you can see all of your mail then mission accomplished. Double check your attachments as well.
~maria
LuvrGirl is offline
The Following User Says Thank You to LuvrGirl For This Useful Post:
ninjaap (05-08-2008)
Old 05-08-2008, 03:34 PM   #20 (permalink)
Ok, sorry guys I'm at work and this is the quickest way I could make it available.
http://rapidshare.com/files/11352721...uev2_setup.CAB
~maria
LuvrGirl is offline
